It is currently Sun Jun 22, 2025 7:01 pm
PostPosted: Thu Mar 02, 2006 1:28 pm
Hi All,
I've been a member here for a little while, just haven't posted. I've thoroughly enjoyed this site and have learned an immense amount!
I'm in the process of my first build and have what may be a naive question.
How snugly should the mortise and tenon joint fit, laterally speaking? Is it typical to allow a little bit of "play" for fitting and fine tuning?
Pete
PostPosted: Thu Mar 02, 2006 1:43 pm
I generally make my mortice and tennon using templates that give a snug, but not tight fit. If yours is loose you could shim one side or the other with peices of veneer. The M&T is not really necessary, it only makes allignment easier.
I hope this helps.
PostPosted: Thu Mar 02, 2006 1:47 pm
Last Name: Beaver
City: Lake Forest
Hi Pete from anoth new guy. I agree with Al, make it easy to slide together but not where it rattles.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Mar 02, 2006 2:07 pm
Hey thanks guys,
That was my first thought, but thought I'd ask anyway. Getting a little concerned about the joint, if you couldn't tell.
Thanks again,
Pete
PostPosted: Thu Mar 02, 2006 3:41 pm
Pete,
   I've always liked a good snug fit when using a mortise and tenon neck joint. I like it to need a little pressure to seat it and then a little work to get apart. If you do leave as much as .005" the joint will slide in nicely with little pressure, but a thin glue application, if you're planning on gluing it, will snug it up as the tenon absorbs the glue and swells slightly.
Regards,
Kevin Gallagher/Omega Guitars
